d.rast.zoom3
M.R. Lassche
lasm at geo.vu.nl
Mon Jul 18 07:17:41 EDT 1994
Here is a modified version of the script d.rast.zoom2, we called it d.rast.zoom3
Most of the script was written by Rick Thompson and I did only a few modifacations to allow the display of up to 2 sites files, and I the checking if input is valid.
--------------BEGIN--------------------
#!/bin/sh
# *** d.rast.zoom3 ***
# Written by Rick Thompson
# modified by Ronnie Lassche. Provided options for color vector displays
# and site parameters for display.
# @(#) d.rast.zoom3: allows repetitive display and interactive d.zooming of up
# @(#) to 1 raster map, and 3 vector files,
# @(#) plus d.zooming back out in the reverse order. Additionally,
# @(#) a region can be saved, the original raster file's region
# @(#) can be returned to, or the user can do a one-time display
# @(#) of a new raster or vector file.
# @(#) Last revision: 7/15/94
# Recognize CDS echo -n
if [ `uname -m` = mips ] ; then
ECHON="/usr/bsd43/bin/echo -n"
# Recognize Solaris 2.3 echo -n
elif [ `uname -s` = SunOS -a `uname -r | sed 's/\...*$//'` = 5 ] ; then
ECHON="/usr/ucb/echo -n"
else
ECHON="echo -n"
fi
if [ "$GISRC" = "" ] ; then
clear
echo "This command must be run from GRASS!"
echo ''
exit 1
fi
# name=''
clear
echo ''
echo "Option: Name of raster map "
echo " key: map"
echo "required: NO"
g.ask type=old element=cell desc=raster unixfile=/tmp/$$
. /tmp/$$
rm -f /tmp/$$
rast="$name"
echo ''
echo "Option: Name of vector map "
echo " key: map"
echo "required: NO"
g.ask type=old element=dig desc=vector unixfile=/tmp/$$
. /tmp/$$
rm -f /tmp/$$
vect="$name"
if [ -n "$vect" ] ; then
gotit=0
while test $gotit -eq 0
do
echo ""
echo "Option: line color "
echo " key: color"
echo " Default: white"
echo "required: NO"
$ECHON "enter option > "
read col1
if test "$col1"
then
if test "$col1" != "aqua" -a "$col1" != "black" -a "$col1" != "blue" -a "$col1" != "brown" -a "$col1" != "gray" -a "$col1" != "green" -a "$col1" != "grey" -a "$col1" != "indigo" -a "$col1" != "magenta" -a "$col1" != "orange" -a "$col1" != "red" -a "$col1" != "white" -a "$col1" != "yellow"
then
echo ""
echo "sorry <$col1> is not valid input"
echo ""
echo "Options : aqua,black,blue,brown,gray,green,grey,indigo,"
echo " magenta,orange,red,white,yellow"
else
gotit=1
fi
else
col1=white
gotit=1
fi
done
echo ''
echo "Option: Name of second vector map "
echo " key: map"
echo "required: NO"
. /tmp/$$
rm -f /tmp/$$
vect2="$name"
fi
if [ -n "$vect2" ] ; then
gotit=0
do
echo ""
echo " key: color"
echo "required: NO"
read col2
if test "$col2"
then
if test "$col2" != "aqua" -a "$col2" != "black" -a "$col2" != "blue" -a "$col2" != "brown" -a "$col2" != "gray" -a "$col2" != "green" -a "$col2" != "grey" -a "$col2" != "indigo" -a "$col2" != "magenta" -a "$col2" != "orange" -a "$col2" != "red" -a "$col2" != "white" -a "$col2" != "yellow"
then
echo ""
echo "sorry <$col2> is not valid input"
echo ""
else
gotit=1
fi
else
col2=white
gotit=1
fi
done
echo ""
echo "Option: Name of third vector map "
echo " key: map"
echo "required: NO"
. /tmp/$$
rm -f /tmp/$$
vect3="$name"
fi
if [ -n "$vect3" ] ; then
gotit=0
do
echo ""
echo " key: color"
echo "required: NO"
read col3
if test "$col3"
then
if test "$col3" != "aqua" -a "$col3" != "black" -a "$col3" != "blue" -a "$col3" != "brown" -a "$col3" != "gray" -a "$col3" != "green" -a "$col3" != "grey" -a "$col3" != "indigo" -a "$col3" != "magenta" -a "$col3" != "orange" -a "$col3" != "red" -a "$col3" != "white" -a "$col3" != "yellow"
then
echo ""
echo "sorry <$col3> is not valid input"
echo ""
else
gotit=1
fi
else
col3=white
gotit=1
fi
done
fi
echo ''
echo "Option: Name of sites file "
echo " key: file"
echo "required: NO"
g.ask type=old element=site_lists desc=sites unixfile=/tmp/$$
. /tmp/$$
rm -f /tmp/$$
sites="$name"
if [ -n "$sites" ] ; then
gotit=0
do
echo ""
echo "Option: Sets the current color to that stated"
echo " key: color"
echo " Default: gray"
echo "required: NO"
read col4
if test "$col4"
then
if test "$col4" != "aqua" -a "$col4" != "black" -a "$col4" != "blue" -a "$col4" != "brown" -a "$col4" != "gray" -a "$col4" != "green" -a "$col4" != "grey" -a "$col4" != "indigo" -a "$col4" != "magenta" -a "$col4" != "orange" -a "$col4" != "red" -a "$col4" != "white" -a "$col4" != "yellow"
then
echo ""
echo "sorry <$col4> is not valid input"
echo ""
else
gotit=1
fi
else
col4=gray
gotit=1
fi
done
gotit=0
do
echo ""
echo "Option: Size, in pixels, in wich the icon is to be drawn"
echo " key: size"
echo " Default: 5"
echo "required: NO"
read size
if test "$size"
then
if test $size -le 0
then
echo ""
echo "sorry <$size> is not valid input"
echo ""
echo "size must be greater then 0"
echo ""
else
gotit=1
fi
else
size=5
gotit=1
fi
done
gotit=0
do
echo ""
echo "Option: Specify the type of the icon"
echo " key: type (+,diamond.box,x)"
echo " Default: x"
echo "required: NO"
read icon
if test "$icon"
then
if test "$icon" != "+" -a "$icon" != "diamond" -a "$icon" != "box" -a "$icon" != "x"
then
echo ""
echo "sorry <$icon> is not valid input"
echo ""
echo "Options : +,diamond,box,x"
echo ""
else
gotit=1
fi
else
icon=x
gotit=1
fi
done
echo ''
echo "Option: Name of second sites file "
echo " key: file"
echo "required: NO"
. /tmp/$$
rm -f /tmp/$$
sites2="$name"
fi
if [ -n "$sites2" ] ; then
gotit=0
do
echo ""
echo " key: color"
echo "required: NO"
read col5
if test "$col5"
then
if test "$col5" != "aqua" -a "$col5" != "black" -a "$col5" != "blue" -a "$col5" != "brown" -a "$col5" != "gray" -a "$col5" != "green" -a "$col5" != "grey" -a "$col5" != "indigo" -a "$col5" != "magenta" -a "$col5" != "orange" -a "$col5" != "red" -a "$col5" != "white" -a "$col5" != "yellow"
then
echo ""
echo "sorry <$col5> not valid input"
echo ""
else
gotit=1
fi
else
col5=gray
gotit=1
fi
done
gotit=0
do
echo ""
echo " key: size"
echo " Default: 5"
echo "required: NO"
read size2
if test "$size2"
then
if test $size2 -le 0
then
echo ""
echo "sorry <$size2> is not valid input"
echo ""
echo ""
else
gotit=1
fi
else
size2=5
gotit=1
fi
done
gotit=0
do
echo ""
echo " Default: x"
echo "required: NO"
read icon2
if test "$icon2"
then
if test "$icon2" != "+" -a "$icon2" != "diamond" -a "$icon2" != "box" -a "$icon2" != "x"
then
echo ""
echo "sorry <$icon2> is not valid input"
echo ""
echo ""
else
gotit=1
fi
else
icon2=x
gotit=1
fi
done
echo ''
fi
d.erase
g.region rast="$rast"
if [ -f $LOCATION/cell/"$rast" ] ; then
d.rast "$rast"
fi
d.vect "$vect" c=$col1
fi
d.vect "$vect2" c=$col2
fi
d.vect "$vect3" c=$col3
fi
d.sites "$sites" color=$col4 size=$size type=$icon
fi
d.sites "$sites2" color=$col5 size=$size2 type=$icon2
fi
g.region save=rastzoomtmp1
response="y"
i=1
until [ "$response" = "n" -o "$response" = "N" ] ; do
clear
echo ''
echo "Please select one of these actions to:"
echo ''
echo "1 - use the interactive d.zoom"
echo "2 - go to the previous zoom"
echo "3 - go to a designated region"
echo "4 - return to <$rast>""'s"" region"
echo "5 - save the current region"
echo "6 - do a one time display of a new raster map"
echo "7 - do a one time display of a new vector map"
echo "8 - quit"
echo ''
$ECHON "Please enter the appropriate number: "
read number
case $number in
1) i=`expr $i + 1`
d.zoom -q
g.region save=rastzoomtmp$i
d.erase
d.rast "$rast"
fi
fi
fi
fi
fi
fi;;
2) i=`expr $i - 1`
if [ $i = 0 ] ; then
echo "No previous zooming windows remain. Would you like to view"
$ECHON "the default region? (y/n) "
read ans
if [ "$ans" = "y" -o "$ans" = "Y" ] ; then
g.region -d res=$res
d.erase
d.rast "$rast"
fi
fi
fi
if [ -f "$vect2" ] ; then
fi
if [ -f "$vect3" ] ; then
fi
fi
fi
elif [ $i -lt 0 ] ; then
echo ''
echo "No previous zooming windows remain."
echo ''
sleep 3
else
g.region region=rastzoomtmp$i
d.erase
d.rast "$rast"
fi
fi
fi
fi
fi
fi
fi;;
3) echo ''
echo 'The region is based on:'
echo ''
echo '1 - raster file'
echo '2 - vector file'
echo '3 - region file'
echo ''
$ECHON 'Please enter the appropriate number: '
read regno
case $regno in
1) echo ''
type="rast";;
2) echo ''
type="vect";;
3) echo ''
type="region";;
esac
g.list "$type"
echo ''
$ECHON "Enter the $type region you want: "
read newreg
g.region "$type"="$newreg"
d.erase
d.rast "$rast"
fi
fi
fi
fi
fi
fi;;
4) g.region rast="$rast"
d.erase
d.rast "$rast"
fi
fi
fi
fi
fi
fi;;
5) echo ''
$ECHON "Enter the name by which to save this region: "
read nreg
g.region save=$nreg;;
6) echo ''
g.ask type=mapset prompt="Please select the tmp raster map:" element=cell desc=raster unixfile=/tmp/$$
. /tmp/$$
rm -f /tmp/$$
rname="$name"
name=''
d.rast -o "$rname";;
7) echo ''
g.ask type=mapset prompt="Please select the tmp vector map:" element=dig desc=vector unixfile=/tmp/$$
. /tmp/$$
rm -f /tmp/$$
vname="$name"
name=''
echo ''
gotit=0
do
echo ""
echo " key: color"
echo "required: NO"
read vnamcol
if test "$vnamcol"
then
if test "$vnamcol" != "aqua" -a "$vnamcol" != "black" -a "$vnamcol" != "blue" -a "$vnamcol" != "brown" -a "$vnamcol" != "gray" -a "$vnamcol" != "green" -a "$vnamcol" != "grey" -a "$vnamcol" != "indigo" -a "$vnamcol" != "magenta" -a "$vnamcol" != "orange" -a "$vnamcol" != "red" -a "$vnamcol" != "white" -a "$vnamcol" != "yellow"
then
echo ""
echo "sorry <$vnamcol> is not valid input"
echo ""
else
gotit=1
fi
else
vnamcol=white
gotit=1
fi
done
d.vect "$vname" c=$vnamcol;;
8) rm $LOCATION/windows/rastzoomtmp*
exit 0;;
esac
done
------------------END-----------
* Ronnie Lassche *
* Department of earth sciences *
* Free University *
* Amsterdam *
* lasm at geo.vu.nl *
