g.setproj
Brian Culpepper brian at cast.uark.edu
Tue Jul 26 14:40:06 EDT 1994
> Im trying to test mapgen, but it is telling me to run
> g.setproj before I run the program.  At the grass prompt,
> I type "g.setproj" and return.  It seems to hesitate and
> drop me out.  It was my understanding that it was to ask
> me a few questions and create a file called PROJ_INFO.
> Is there something I am supposed to add to the line
> g.setproj  or is there an alternate way to create this
> file without using the command.
> Thanks for any help.
> Kym M. Lenkus
> Davidson Laboratory
Kym,
	You can create these files with your text editor (vi) under
your PERMANENT mapset, but g.setproj will build these files for you
IF you are the owner of the PERMANENT mapset...   You MUST be the
Have a great day
R. Brian Culpepper                                 Research Assistant
Center for Advanced Spatial Technologies           (fax) 501 575-3846
Rm. 214 Ozark Hall                                (work) 501 575-6159
University of Arkansas                            brian at cast.uark.edu
Fayetteville, AR 72701
All opinions are my own and do not necessarily reflect those of the
Center for Advanced Spatial Technologies or the University of Arkansas.
