No subject
Susan Stitt susan at its.nbs.gov
Wed Jul 27 10:24:29 EDT 1994
>From grass-lists-owner at max.cecer.army.mil Tue Jul 26 22:06:20 1994
>From: shaji at gandalf.Berkeley.EDU (Shaji Sebastian)
Subject: Question about Viewing DLG files in GRASS
>Date: 27 Jul 1994 03:57:15 GMT
>Organization: Statistics Dept., U. C. Berkeley
>I have spent the last two days trying to view DLG files in  GRASS
>that I installed on a SUN workstation and I am feeling rather
>frustrated. I would be very obliged if someone knowledgeable
>could tell me what I am doing wrong.
>USGS-NMD  DLG DATA - CHARACTER FORMAT - 09-29-87 VERSION
>SAN FRANCISCO, CA                        1978,        100000.  F08
                                                            >^@^@^@\0 0 3636
>     3     1    10     2 0.25400000000D+01     4     0     4     1
>-0.122007030000000D+09   0.370370300000000D+08   0.000000000000000D+00
>0.000000000000000D+00   0.000000000000000D+00   0.000000000000000D+00
>0.10000000000D+01 0.00000000000D+00 0.00000000000D+00 0.00000000000D+00
>SW       37.500000 -122.250000         566295.14  4150401.44
>NW       37.750000 -122.250000         566072.83  4178137.43
>NE       37.750000 -122.000000         588098.80  4178342.21
>SE       37.500000 -122.000000         588392.23  4150606.89
>RAILROADS              0   142   142 010    29    29 010   169   169   1
>N    1   566295.14  4150401.44           2           0     0
>163    -8
>and when I finally finished with  g.region it looked like this:
>                               IDENTIFY REGION
>           ============================= DEFAULT REGION ========
>           |          Default North:37:45N                     |
>           |           =======  YOUR REGION  =======           |
>           |           | NORTH EDGE:37:45N_____    |           |
> Def. West |WEST EDGE  |                           |EAST EDGE  | Def. East
> 122:15W   |122:15W____|                           |122W_______| 122W
>           |           | SOUTH EDGE:37:30N_____    |           |
>           |          Default South:37:30N                     |
>           PROJECTION: 3 (Latitude-Longitude)         ZONE: 0
>                   Default   GRID RESOLUTION   Region
>                     0:00:06.47482st-West ---   0:00:06.47482
>                     0:00:06.47482th-South --   0:00:06.47482
>              AFTER COMPLETING ALL ANSWERS, HIT <ESC> TO CONTINUE
>                            (OR <Ctrl-C> TO CANCEL)
>Thanks again in advance.
>Shaji
Shaji,
When you import an optional format dlg file, it is in
UTM coordinates.  The header you created is in lat-long.
You need to use the UTM coordinates:
north: 4178342.21
south: 4150401.44
east:  588392.23
west:  566072.83
and you appear to be in UTM zone 10.
The person who suggested using the command: g.region vect=(filename)
is correct, this will set the region to whatever the region is for the
vector file you created...
Hope this helps.
Susan Stitt
National Biological Survey   (303) 969-2596
Technology Transfer Center   sstitt at its.nbs.gov
