v.in.ascii
Rick Thompson rick at cast.uark.edu
Wed Jul 27 11:47:56 EDT 1994
Hi, Dan.
  Compare the eastings and northings in your ascii file with 'good' ascii files
that display. They are probably reversed. If you would like a script I use to
do this (from a related task), let me know. Rick
> 	I am presently trying to convert lat-lon coordinates into vector maps.
> I have successfully converted the data into UTM form with the m.ll2u command
> and then put it into grass ascii format using an awk program.  I then use the
> v.in.ascii command and a vector map is created.  This is where I run into
> trouble.  When I use the d.vect command the map does not display.  I tried
> other maps that had been create other ways and they work so I don't know what is
> wrong.  The map that I created is within the region so it should display.  If
> there is anything that I didn't do or set please respond.
Rick Thompson-   Research Assistant           E-mail: rick at cast.uark.edu
Center for Advanced Spatial Technologies      Telephone: (501) 575-5736
Ozark Hall Rm. 12                             Fax: 575-3846
University of Arkansas
Fayetteville, AR 72701
