No subject
kilee at CC.UManitoba.CA kilee at CC.UManitoba.CA
Thu Jun 9 18:03:32 EDT 1994
Dear GRASSers ,
I am installing GRASS4.1 on IBM RS/6000 running AIX3.2.
Compilation of GRASS programs almost finished, but
XDRIVER generation is failed for the below reason.
The following is a message after sh of GISGEN.<header>.
------------------  cited -----------
        /home/kilee/grass4.1/gmake4.1 XDRIVER
/home/kilee/grass4.1/src/display/devices/XDRIVER/XDRIVER
  make -f OBJ.ibm6000/make.rules
        rm -f OBJ.ibm6000/SWITCHER.o
        cc -O -D_NO_PROTO    -I/home/kilee/grass4.1/src/include -DUSE_TERMIO -c SWITCHER.c
"SWITCHER.c", line 45.0: 1506-041 (S) Parameter list cannot contain fewer parameters than required by macro def
inition.
make: 1254-004 The error code from the last command is 1.
Make Quitting.
make: 1254-004 The error code from the last command is 2.
Make Quitting.
GISGEN failure at STEP: src/display/devices/XDRIVER
------------ end of cite
Currently, I use Motif Window Manager( mwm); therefore, I don't need
X11r3. As another reference, my GISGEN.<header> is the followings,
CC                  = cc
ARCH                = ibm6000
GISBASE             = /home/kilee/grass4.1/ibm6000
UNIX_BIN            = /home/kilee/grass4.1
DEFAULT_DATABASE    = /home/kilee/grass.data
DEFAULT_LOCATION    = spearfish
COMPILE_FLAGS       = -O
LDFLAGS             = -s
XCFLAGS             = -D_NO_PROTO
XLDFLAGS            =
XINCPATH            =
XMINCPATH           =
XLIBPATH            = -L/usr/lib
XTLIBPATH           = -L/usr/lib
XMLIBPATH           = -L/usr/lib
XLIB                = -lX11
XTLIB               = -lXt
XMLIB               = -lXm
XEXTRALIBS          =
TERMLIB             =
CURSES              = -lcurses $(TERMLIB)
MATHLIB             = -lm
#                   LIBRULE = ar ruv $@ $?
#                   LIBRULE = ar ruv $@ $?; ranlib $@
#                   LIBRULE = ar ruv $@ $?; ar ts $@
#                   LIBRULE = ar rc $@ `lorder $(OBJ) | tsort`
USE_TERMIO          = -DUSE_TERMIO
USE_MTIO            =
USE_FTIME           =
DIGITFLAGS          = -DUSE_SETREUID -DUSE_SETEUID -DUSE_SETPRIORITY
VECTLIBFLAGS        =
GETHOSTNAME         = -DGETHOSTNAME_OK
My problem is mainly on XDRIVER generation and
GRASS Graphic Windows related to it.
Grass menu( with prompt GRASS-GRID >) is working well,
though no display.
Someone help me?
In the mean time, I owe Yung-Tsung Kang, Center of Remote Sensing
at MSU, for installation on IBM RS/6000 AIX 3.2.
Thank Kang.
                                Kiwon
e-mail; kilee at ccu.umanitoba.ca
