continued heartburn over r.in.tiff
    martijn at scanner.frw.uva.nl
    Thu Jun 16 06:51:15 EDT 1994
For what it's worth:
After having had trouble with the r.in.sunrast method of import, we
changed over to r.in.tiff and haven't had any trouble since. Perhaps you
should try the reverse:
- use `xv' to convert the tiff file to sunraster format
- use r.in.sunrast to import
This method worked at our site about half of the time, perhaps you'll
have better luck...
P. Martijn van Leusen
Institute of Prehistory, University of Amsterdam   martijn at scanner.frw.uva.nl
On Tue, 14 Jun 1994, BARNES DAVID wrote:
> 	We continue to have troubles with r.in.tiff. Our attempts to import
> digital image files from scanner-created tiff file format files is unsuc-
> cessful. The raster map file and support files created by r.in.tiff ..seem..
> to be in order but the display of this file in GRASS 4.1 is a blank white
> screen or sometimes nothing (black). During the r.in.tiff procedure all seems
> to go well but at the end of the operation the erro message of "segmentation
> fault" occurs. We are stumped and befuddled (several months into this problem).
> We do not know if the r.in.tiff utility as constructed fromt the GRASS 4.1
> bundle is at fault or what. HELP!
> May thanks in advance.
> Dave Barnes, Shrinivas Reddy
> Western Michigan University, Department of Geology
> Great Lakes Coastal Research Program
