r.in.tiff
Trond Rinde trinde at donau.boku.ac.at
Wed Jun 22 12:24:45 EDT 1994
Hello!
I try to use the r.in.tiff program to import a scanned map, but all
I get is a map layer containing only zero values. Does anyone know what
could be the problem. The message I get when I run r.in.tiff is:
>r.in.tiff -v input=liezen.tif output=soil.map.raw
Reading liezen.tif...TIFF Directory at offset 0x1e
  Subfile Type: (0 = 0x0)
  Image Width: 1027 Image Length: 1444
  Resolution: 300, 300 pixels/inch
  Bits/Sample: 8
  Compression Scheme: none
  Photometric Interpretation: RGB color
  Samples/Pixel: 3
  Rows/Strip: 1444
  Planar Configuration: single image plane
  1 Strips:
      0: [     204,  4448964]
1027x1444x24 image
 8 bits/sample, 3 samples/pixel
256 truecolor NOT SUPPORTED YET
Creating SUPPORT Files for soil.map.raw
done.
Thank you in advance!
Trond Rinde
Siv.ing. Trond Rinde
Institut f. Wasserwirtschaft, Hydrologie und konstruktiven Wasserbau
Universitet f. Bodenkultur
A-1190 Wien, Nussdorfer Laende 11
tel: 	1 36 92 924 352
fax: 	1 36 92 924 350
email:	trinde at donau.boku.ac.at
