Importing DXF files
Nalneesh Gaur ngaur at apwk01g3.abrfc.noaa.gov
Tue Mar 1 09:15:58 EST 1994
I have had the same problem before. You can try the GRASS command
v.alabel to bulk label all the areas, The areas labeled can then be
reclassified using v.reclass, resulting in the file that you had.
Nalneesh Gaur, River Forecast Center, TULSA
