MAPGEN
George Taylor
oregon at chaos.ATS.ORST.EDU
Thu Mar 3 19:40:35 EST 1994
Hello,
Can an experienced MAPGEN user explain if the following task is
possible and how one might accomplish it.
I have taken the output from r.contour (after running v.support)
and brought that data set into MAPGEN using the "make.line" command.
I've also imported the attributes with "make.label". After running
"show.sh" , the lines and labels are plotted in the graphics window,
but there is one label for the entire length of the line.
I would like to plot that line and with its attribute label it
at some specified interval. I've tried using the more fundamental
"lines" command but am still unable to produce a labelled contour
line. Is this possible with MAPGEN?
Wayne Gibson
Oregon State University
