v.trim
    Jim Nolan
    jim%sar_ws at sun1.wwb.noaa.gov
    Fri Mar  4 08:43:31 EST 1994
What effect does a negative factor have on v.trim? For
example, I have a script that uses the following:
	v.trim input=infile output=outfile factor=-0.0001
and this works like a champ. However, if I type the same
on the command line I get no results on the same infile.
Anyone know why this may occur.
thanks,
Jim
______________________________________________________________________
My email address will not work correctly when you try to "Reply",
it must be manually changed to jim at sar_ws.fb4.noaa.gov.
   Jim Nolan            	Phone: (301) 763-7439
   National Ice Center    	Fax: (301) 763-4621
   4251 Suitland Rd.    	email: jim at sar_ws.fb4.noaa.gov
   FB#4, Rm. 2301
   Washington, DC 20395
