PhotoCD & UNIX? - PCD to TIFF?
Ronald Thomas
ront at picea.CFNR.ColoState.EDU
Wed Mar 9 19:45:04 EST 1994
We have some National Aerial Photography Program images scanned onto a
Kodak PhotoCD (multisession), and want to import them into our UNIX
GIS system (GRASS). My questions:
1) Can a PhotoCD be mounted on a UNIX system? If so, how?
(I tried the standard "mount -r /dev/sr0 /cdrom", but no luck
-- is it a specific file system type that needs to be noted?)
I can attach the CD to either a SPARCclassic or an IPX.
2) If # 1 is possible, can I just copy the *.pcd files I want to my
SPARCclassic and use as they are, or do I need to run "dos2unix"
on them?
3) Is there a PCD to TIFF converter around, perhaps as a new addition
to the PBMplus toolkit? (I'd like a straight, hi-resolution
conversion of the PCD format to TIFF)
4) Is there a UNIX (SunOS 4.1.3 or Sol 2.2) viewer of Kodak
PhotoCD's, or a program that views/reads/converts the
*.pcd format?
Some background:
Each *.pcd image is > 4M , and Corel(Draw/PhotoPaint) will not import at
the highest resolution (on a 486/66 w/8M RAM). This was my initial plan --
to use Corel(something) to convert to TIFF.
Any help sent our way will be GREATLY appreciated!!
Ronald Thomas ront at meeker.cfnr.colostate.edu
Natural Resource Spec. (GIS) ^^^ Phone: 303-586-3565 x285
Resources Management Division ^^ ^^^^^ FAX: 303-586-4702
Rocky Mountain National Park ^^^ ^^^^^^^ Estes Park, CO 80517
