ERDAS - GRASS conversions
Wang Song
wang at cast.uark.edu
Wed Mar 23 13:45:12 EST 1994
If your site have GRASS4.1 installed, you should be able to
find a command "i.in.erdas" which will do the job you required. The
source code is in alpha section of the GRASS distribution.
In another way, you may use "i.tape.other" to read in a
ERDAS LAN file by skipping 128 byte header and selecting the BIL
format. Rest of the information could be found from the output of
running ERDAS LISTIT command.
Good Luck.
Song Wang
CAST/NCRI
12 Ozark Hall
University of Arkansas
> I'm trying to find out if there are any
> modules within Grass to convert ERDAS .LAN
> files to Grass raster files.
> Alan Frank
> gograss at blaze.trentu.ca
