more digitizer
Malcolm Williamson
malcolm at cast.uark.edu
Wed Mar 23 15:15:11 EST 1994
Kathy,
It sounds like you need to compile src/mapdev/digitizers/calcomp. You should
be able to cd to this directory and run gmake4.1, then run the MAKELINKS
command.
Hope this works for you!
> Thank you to Malcolm Williamson and Ken Sibley for responding to my
> question about setting up the CALCOMP digitizer. I think we figured out
> which available digitizer we need "cc95f6_16", however it also appears
> that we need a subdirectory in the etc/dig_drivers directory corresponding
> to the digitizer and that we need to change the ownership on this to "root".
> Our dig_driver directory has only 2 subdirectories "kurta" and "kurta2".
> What do we need to do to get an appropriate subdirectory set up? Also
> am I missing something, or can I assume that setting up the subdirectory in
> the dig_drivers directory will be the last step, assuming the "cc95f6_16" is
> the correct format for our digitizer?
> Thanks for any light you may be able to shed on this issue.
> Kathy Doyle
Malcolm D. Williamson - Research Assistant E-mail: malcolm at cast.uark.edu
Center for Advanced Spatial Technologies Telephone: (501) 575-6159
Ozark Rm. 12 Fax: (501) 575-3846
University of Arkansas
Fayetteville, AR 72701
