No subject
    grass-lists-owner at max.cecer.army.mil
    Tue May  3 06:06:58 EDT 1994
***** UNDELIVERABLE MAIL sent to chungh, being returned by marsh!chungh *****
mail: Error # 2 'Problem with mailfile' encountered on system marsh
Received: from max.cecer.army.mil by marsh.cs.curtin.edu.au with SMTP id AA06564
  (5.67a/IDA-1.5 for <chungh at cs.curtin.edu.au>); Tue, 3 May 1994 18:06:35 +0800
Received: from amber.cecer.army.mil by max.cecer.army.mil with SMTP id AA03145
  (5.67a/IDA-1.5 for <chungh at cs.curtin.edu.au>); Tue, 3 May 1994 05:00:12 -0500
Received: from max.cecer.army.mil by amber.cecer.army.mil (4.1/SMI-4.1)
	id AA06468; Tue, 3 May 94 04:52:49 CDT
Received: from pike.assetplus (pike.cecer.army.mil) by max.cecer.army.mil with SMTP id AA02907
  (5.67a/IDA-1.5 for <grassu-people at moon>); Tue, 3 May 1994 04:52:49 -0500
Received: from amber.cecer.army.mil by pike.assetplus (5.0/SMI-SVR4)
	id AA05802; Tue, 3 May 1994 04:52:45 +0600
	id AA06462; Tue, 3 May 94 04:52:41 CDT
Received: from david.zfe.siemens.de by max.cecer.army.mil with SMTP id AA02903
  (5.67a/IDA-1.5 for <grassu-list at max.cecer.army.mil>); Tue, 3 May 1994 04:52:39 -0500
Received: from ztivax.zfe.siemens.de by david.zfe.siemens.de with SMTP id AA14307
  (5.67a/IDA-1.5 for <grassu-list at max.cecer.army.mil>); Tue, 3 May 1994 11:52:26 +0200
Received: from icrz3.bgl.kwu.siemens.de (kwu-gw) by ztivax.zfe.siemens.de with SMTP id AA17510
  (5.67a/IDA-1.5 for <grassu-list at max.cecer.army.mil>); Tue, 3 May 1994 11:52:22 +0200
Received: from sco4t.erl.kwu.siemens.de by icrz3.bgl.kwu.siemens.de with SMTP id AA16335
  (5.65c/IDA-1.5 for <grassu-list at max.cecer.army.mil>); Tue, 3 May 1994 11:51:59 +0200
Received: by sco4t.erl.kwu.siemens.de id AA11891
  (5.65c/IDA-1.5 for grassu-list at max.cecer.army.mil); Tue, 3 May 1994 11:51:42 +0200
Message-Id: <199405030951.AA11891 at sco4t.erl.kwu.siemens.de>
Subject: Re: problems compiling tcltk
Sender: grass-lists-owner at max.cecer.army.mil
Reply-To: grassu-list at max.cecer.army.mil
Precedence: Bulk
Sender: grass-lists-owner at moon.cecer.army.mil.
Reply-To: grassu-list at moon.cecer.army.mil.
Precedence: Bulk
Date: Tue, 3 May 1994 11:51:41 +0200 (MESZ)
In-Reply-To: <9014.9405030918 at sun.aston.ac.uk> from "charnotw" at May 3, 94 10:18:27 am
X-Mailer: ELM [version 2.4 PL22]
Mime-Version: 1.0
Content-Type: text/plain; charset=US-ASCII
Content-Transfer-Encoding: 7bit
Content-Length: 740
> Hi Grasshoppers
> am trying to compile tcltk so I can use tcltkgrass, however I keep getting the error message
> cc -O -I. -I. -DHAVE_UNISTD_H=1 -DNO_FLOAT_H=1 -DNO_STDLIB_H=1 -DNO_STRING_H=1 -DNEED_MATHERR=1     -DTCL_LIBRARY=\"/usr/local/lib/tcl\" tclAppInit.o libtcl.a -lm -o tclsh
> ld: Undefined symbol
>    __lib_version
Hello,
	which platform are You using?
	I know similar problems on SUN's using SPARCworks acc, if
	the library path points to the normal cc libraies, not the the
	SPARCworks libraries!
Greetings
Dipl. Geol. Andreas Holz		e-mail: asholz at cip.informatik.uni-erlangen.de
					e-mail: holz at oi32.kwu.siemens.de
