Compiling Tcltkgrass
Tom Moore
tmoore at pnfi.forestry.ca
Thu May 12 08:14:12 EDT 1994
In mailgate.grass.user you write:
>>>>> "Kym" == grassu-list <grassu-list at max.cecer.army.mil> writes:
Kym> Currently, the program will compile fine with a few warnings.
Kym> The problem is I get a core dump when I try to run the
Kym> program. The warnings are the following:
Kym> Has anyone had this problem before?
What compiler are you using? If it is gcc you must use the
compiler switch '-fwritable-strings'.
Tom
Tom Moore tmoore at pnfi.forestry.ca
Petawawa National Forestry Institute
Canadian Forest Service, Box 2000, Chalk River +1 (613) 589-3048
ONT K0J 1J0 CANADA +1 (613) 589-2275 telefax
