r.water.outlet
Richard Beecham
beecham at aerg.canberra.edu.au
Sun May 22 10:33:29 EDT 1994
Piotr
I also had this problem - the manual and help give the wrong format for
import - I ended up using another program called r.upbasin.downpath from
the anonymous ftp site in the /incoming directory at
landfill.rutgers.edu
- note you have to install the WRAT programs in src.contrib/NMSU to use
this. Hope this helps
------------------------------------------------------------------------I
Richard Beecham email:beecham at aerg.canberra.edu.au
Hydrology Unit phone:(02) 895 7169
NSW Department of Water Resources fax :(02) 895 7834
Parramatta NSW 2124
Australia
On Sun, 22 May 1994, Piotr Labuda wrote:
> Hello!
> Does anybody succeeded to run r.water.outlet? I don't know
> why but I can't run this command.
> Best regards
> Piotr Labuda
