fortran to c
E.A. Koster
ekoster at let.rug.nl
Wed Oct 5 03:13:57 EDT 1994
In article <9410042253.AA58878 at halcon.dpi.udec.cl>, you write:
> I wan to compile s.db.rim and v.db.rim
> somebody has tell me that I must transponse it from fortran
> to C with a F2c program....Does anybody made this before???
> How I do this??? How I can compile these programs after this?
> My configuration:
> Sun SPARC 20
> SOlaris 3.3
> thank's
Yes, I tried it, although I heard of people doing this without any problem
I didn't manage.
After you have translated all fortran-code with f2c you have normal C files
which you can compile with your normal c-compiler. I don't know if you can
use the set-up script from Grass directly, but I think you have to change some
things in this.
good luck,
Elwin
