irix5.2 compile (RESOLVED, FATTO)
josh at turb01.dmc.com
Mon Oct 10 10:48:04 EDT 1994
Would you mind posting or sending the Irix5.2 notes? I failed also to
compile those modules in my brief attempt.
Grazie,
Josh
> Ir. Bart Cosyn
> EC- Environment project
> CRS4
> Environmental modelling group
> Via Nazario Sauro, 10
> Tel +/39/70/2796280
> Fax +/39/70/2796216
> E-mail: bcosyn at crs4.it
>Hi Bill,
>On Fri, 7 Oct 1994, Bill Brown wrote:
>> Bart,
>> Here's a copy of my IRIX compile notes:
>about the i.point,i.vpoint and i.orthophoto! It works fine no more
>problems for compiling it!
>Well about the monitor I can tell you that the problem was that I
>forgot to uncomment the last :: any display so he did not took the
>IRIS diplay. In fact a bit stupid but at least it's resolved.
>Your notes were correct so I have to thank you for your BIG HELP.
> Thanks, Bart
Joshua Lieberman, Ph.D. josh at turb01.dmc.com
ENSR Consulting and Engineering wasser at world.std.com
35 Nagog Park, Acton, MA 01720 508-635-9500
