thinning polygons
    Scott Miller
    miller at tucson.ars.ag.gov
    Wed Oct 19 14:37:50 EDT 1994
Good day,
I've been working with a stream network map layer that was
originally created in ARC/INFO.  The streams were digitized
at a very fine resolution, and most of the streams appear as
polygonal features, even those with a width of < 2m.  I would
like to create a generalized data layer from this by
running a vector down the middle of the polygons, but prefer
to avoid the brute-force approach of digitizing each stream
section.
I have tried running the r.thin routine in GRASS on the raster
map of the streams, with minimal success; the streams become
disjointed, and a discontinuous stream system is the result.
An additional problem is the presence of side-channels; the
confluences are at the edge of the polygons, but should be
moved towards the center of the stream in the center of a
resultant vector map.
My question is: is there an automated method for running a
vector down the center of a given polygonal feature, or
collapsing a polygonal feature to a given width?  If not in
GRASS, I have some familiarity with ARC, as well.
Thanks in advance,
Scott
Scott Miller			e-mail: miller at tucson.ars.ag.gov
USDA - ARS SWRC			phone:  (602) 670-6481 ext. 342
2000 E. Allen Rd.		fax:  (602) 670-5550
Tucson, AZ  85721
