RE - Monitor's ...
Pascal Gouery - UHB - 99 33 52 52
gouery at uhb.fr
Thu Oct 27 04:16:17 EDT 1994
In article <9410252120.AA05190 at tsalmoth.colorado.edu>, dunnj at tsalmoth.colorado.edu (DUNN JEREMY SIMON) writes:
> Hi there I've been trying to open and run a monitor in grass using d.mon
> I get the error message as below when I try to do this
> x0
> Graph_Set: can't open
> so what do I need to set my DISPLAY to ?
> It's a DEC Alpha , called polarbear .
> I'm running it remotely from another machine (DECSTATION)
> Any help would be greatly appreciated.
> Jeremy
Hello Jeremy,
You have two things to do :
. Set your display as the DECSTATION name oe IP number
(witch is really your display, It would be the X-terminal if you
work on a X-terminal ...)
setenv DISPLAY <IPnbr>:0.0 or setenv DISPLAY <name>:0.0
. On the DECSTATION (a Decterm open'd directly from your session
manager for example) authorize your alpha to display on the
DECSTATION (I think on ULTRIX a thing like "xhost + <host>"),
Just "xhost +" enables any host to display on your screen.
(on VMS machines you do this over the "option" "security" menu
from the session manager)
. To see if it's Ok, you can run for example the "xclock" of
your Alpha or any other Xtool
Hope it help you,
: Pascal GOUERY : Tel.: 99.33.52.79 :
: S.I.R.E. : 99.33.51.24 :
: Univ. Rennes 2 : Fax.: 99.33.52.73 :
: 6, Av G.Berger : :
: 35043 RENNES CEDEX : e.mail: gouery at uhb.fr :
