Problem with v.digit
    William Voigt
    voigtw at nature.Berkeley.EDU
    Tue Sep  6 16:34:11 EDT 1994
I've copied grass source & binaries from one disk to another recently, &
ave been plagued with various problems, mostly related to ownership &
file modes. The latest perplexing problem is when I use v.digit on a
vector map.  I invoke the command, select <none> for the digitizer, and
give the name of a dig file.  The program responds with the message that
its drawing the file, but I only get a fram outline (white), but no dig
outlines (which should be magenta).  The program seems to hang at this
point.  When I went to another shell & killed the v.digit command, the
desired vector map appeared in the x0 monitor.  Does anyone have any
ideas or similar experiences?
Thanks for your help.
	--Bill Voigt voigtw at nature.berkeley.edu
