Grass and Autocad
    Malcolm Williamson
    malcolm at cast.uark.edu
    Wed Sep  7 14:28:02 EDT 1994
> Hi Grassers,
> I would like to use some old digitized maps from autocad i received from
> a third party. I would like to know which is the easiest way to import it
> in Grass. Surely DXF format must fit but is it possible to maintain
> the DWG format? If not, is Grass capable to import very large DXF files?
> 			Hope someone can answer to this!
> 				Bart
Hi, Bart
Sorry, but there is no way to import DWG format to GRASS; you're stuck with
DXF (v.in.dxf). Size should not pose a problem. Good luck!
Malcolm D. Williamson - GIS Specialist           E-mail: malcolm at cast.uark.edu
Center for Advanced Spatial Technologies      Telephone: (501) 575-6159
Ozark Rm. 12                                        Fax: (501) 575-3846
University of Arkansas
Fayetteville, AR 72701
