Hi Grassers, I would like to use some old digitized maps from autocad i received from a third party. I would like to know which is the easiest way to import it in Grass. Surely DXF format must fit but is it possible to maintain the DWG format? If not, is Grass capable to import very large DXF files? Hope someone can answer to this! Bart
