r.le version 2.1 manual
    BAKERWL at UWYO.EDU
    BAKERWL at UWYO.EDU
    Fri Sep 30 16:06:21 EDT 1994
One way to find out if people are using your contributed code is to
put a corrupt file on the moon and then wait to see if there are any
sparks.  This wasn't my intention, but the Wordperfect file in the
doc subdirectory of rle21.tar.Z on the moon is corrupt.  As a short
term fix I have just sent a new version of this file.  It is called
rle21.wp52b and it is a Wordperfect 5.2 file containing the documentation.
You MUST download this after setting ftp to BINARY mode.  It is not
compressed or tarred.  I did successfully download it, move it to my
PC and it looks fine in Wordperfect 5.2.  I also read it into Wordperfect
6.0 and it's OK there as well, after conversion.  I also sent a
file called rle21.README2 which explains about the corrupt file and
this new file.
I appreciate the many suggestions to use Wordperfect to create a
postscript file to send to the moon.  However, I have so far not
been able to get postscript output from Wordperfect that will print
correctly from my Sun workstation.  It gets garbled for some reason,
perhaps because of the equations.  I'm still working on it and will
put a postscript version on the moon whenever I can get it to work.
If anyone else successfully creates a postscript version from the
Wordperfect file, please let me know.
Sorry about the inconvenience.
	Bill Baker
	bakerwl at uwyo.edu
