v.trim
    Amy Keeley
    akeeley at ncdc.noaa.gov
    Fri Sep 30 16:13:54 EDT 1994
Yesterday I sent out a message
asking for advice about v.trim.
Scott Miller had replied that I
should check my region (thanks
for the reply Scott!).  I guess
that I should have mentioned that
the region is definitely fine.  In
fact, my map covers the continental
U.S.A.  and the only areas included
in the output "trimmed" map are
North and South Dakota, Texas,
West Virginia, and a portion of
Virgina.  How can I successfully
get rid of my extra nodes??? Any advice
would be greatly appreciated!
Amy
>Hi.  I've been trying
>to use v.trim on a vector map
>in order to get rid of all
>excess nodes.  To do this,
>a trim value of zero should
>be used, otherwise "small
>spurs", will be deleted
>also.  At this point, all
>that I want to work with is
>the nodes.  However, the resulting
>output map is only a small
>portion of my original map.
>Why isn't the rest of the
>map being run through the
>v.trim process?
>Amy Keeley
_________________________________________
>Amy,
>Have you checked to make sure your g.region is set
>such that the entire area you want to process
>is encompassed by you current region?
>Good luck,
>Scott
