HELP with v.build
    mike camann
    camann at pick.uga.edu
    Tue Apr 11 08:00:00 EDT 1995
HELP!!
(My apologies to those of you who have received this already, but I'm
re-sending it because there was evidently a problem with the mailing
list recently-- I know that most of you did not get it the first time.
Furthermore, due to the nature of the problem, I've cross-posted to
grassp.)
I am having a problem with v.support [build], or more specifically,
with $GISBASE/etc/v.build, which builds vector topologies.  I'm running
GRASS 4.1.5 on a Sun SPARC 20 under Solaris 2.4.  The programs compiled
just fine, but v.build produces a segmentation fault and a core dump
EVERY time.  It works just fine on my old (slow) Sun 4/280 under SunOS
4.1, so I suspect a problem with the "port" to Solaris.  PLEASE contact
me if you have a working v.build (or v.support [build]) under Solaris
2.4 so I can figure out how to get mine working.  To find out, try
$GISBASE/etc/v.build map=any_vector_map
or
v.support map=any_vector_map option=build
I've traced the problem, through several layers of function calls deep
within the convoluted vector library, to a call to
Vect_x_read_head_binary (Map, dhead) in
$GISBASE/src/mapdev/Vlib/x_rw_binary.c, which appears to be part of a
series of unsupported library routines.  I won't have time to pursue it
further for several days, so I've decided to appeal for help.
Unfortunately, I need v.build up and running on this machine rather
badly.
I was surprised to see unsupported libraries comprising part of the
main GRASS module-- these particular libraries have been in use for at
least a full release cycle (sometime in version 3.x), yet remain
"unsupported".  On a related note, can someone give me Dave Gerdes
email address?  Dave is the author of those routines and can perhaps be
of help.
Thanks in advance....
Michael Camann                  camann at dial.pick.uga.edu
Department of Entomology        camann at sparc.ecology.uga.edu
University of Georgia           (706) 542-2303 voice
Athens, GA 30602                (706) 542-2640 FAX
