tree cutting determination
Jocelyn Aycrigg aycrigg at gis.uiuc.edu
Thu Aug 31 13:22:21 EDT 1995
----- Begin Included Message -----
>From grass-lists-owner at max.cecer.army.mil Thu Aug 31 10:26:36 1995
Subject: tree cutting determination
Sender: grass-lists-owner at max.cecer.army.mil
Reply-To: grassu-list at max.cecer.army.mil
Sender: grass-lists-owner at moon.cecer.army.mil.
Reply-To: grassu-list at moon.cecer.army.mil.
Precedence: Bulk
Precedence: Bulk
Date: Thu, 31 Aug 1995 08:34:40 -0500 (CDT)
X-Mailer: ELM [version 2.4 PL23]
Mime-Version: 1.0
Content-Type: text/plain; charset=US-ASCII
Content-Transfer-Encoding: 7bit
Content-Length: 669
Hello,
I have a problem I would like to work on in Grass, and
wonder if anyone else has done something like this
and can tell me how to go about it, especially someone
in military circles.
We need to cut some trees to get a clear shot from
firing points to targets on a new range.  We would like
to leave as many trees as possible and only cut those
"in the way".  Is it possible to take into consideration
the height of the trees and the elevation from which they
grow to see which will "interfere" with the line of sight
between target and firing point?
Appreciate any assistance.
Carla Elenz
Camp Grayling, MI
elenz at osiris.cos.uiuc.edu
517-348-7621 ext 3306
----- End Included Message -----
Carla,
You may want to try the r.los command.  It sounds like it may work in your situ
ation.
Good luck,
Jocelyn L. Aycrigg
Department of Geography
220 Davenport Hall
607 S. Mathews
Univ. of IL
Urbana, IL  61801
tel: 217-244-0306
email: aycrigg at gis.uiuc.edu
Carla,
You may also want to check out r.traj.
"r.traj generates a raster map layer showing cells that can be hit from a firin
g point by shells from a user-specified weapon.  Cells are marked with integer
alues that represent the muzzle firing angles required to hit them.  It takes a
 "elevation" raster map as input.
Steve Hall
Lockheed Martin Missiles and Space
B/154 O/8K-01
Sunnyvale, CA  94089-3504
tel (408) 742-2903
email hall_s at lmsc.lockheed.com
