LABELING to a monitor ???
Bonnie Weller weller at osiris.cso.uiuc.edu
Thu Aug 3 13:09:16 EDT 1995
I want to display labels to the monitor.  Can this be done using GRASS?
I tried using d.paint.labels without luck.  The labels will display
using p.map but I cannot draw labels from the command line.
Has anyone wriiten a script to do this ?
Has anyone else using d.paint.labels (GRASS4.1) had problems with it ?
How can I display labels for vector and raster files.
I would prefer not to use p.map if possible.  (or ps.map either)
Can labeling to the screen be done or should I forget it and wait to
do annotation when we switch over to ARC/Info next year ??
Thanks for the help
Bonnie
weller at acca.nmsu.edu
