Help using v.in.dxf
    Cosyn Bart
    Bart.Cosyn at rug.ac.be
    Wed Dec 20 07:00:00 EST 1995
On Wed, 20 Dec 1995, mohdnaka wrote:
> Any idea, where I did anything wrong when running the v.in.dxf command.
You didn't do anything wrong. Indeed dxf does not include the attribute
values in his header or file. You will need to add the attributes
manually using v.digit.
Any case also I should be very interested to find out a way to keep these
information but I think the problem is a format problem of dxf and not a
problem of the v.in.dxf module!
                        Bart
        | ir. Bart Cosyn                                  |
        | VLIR-project Tunisia                            |
        | Laboratory for Hydrology and Water Management   |
        | University of Gent                              |
        | Coupure 653, B-9000 Gent                        |
     | Belgium                                    |
        | Tel: +/32/9/2646137                             |
        | Fax: +/32/9/2646236                             |
        | E-mail: bcosyn at allserv.rug.ac.be                |
        | URL: http://taoren.rug.ac.be/                   |
