Hi, Does anyone know why one can't use patterns in ps.map like you can p.map? Would anyone have any suggestions at getting around this problem? The only way around this that I can figure out is saving a map in sunraster format and then importing it into grass as a raster file, and then ps.mapping the raster file. Any simpler solutions out there? Thanks, Christine
