IBM 1GByte disk (DPES 31080) crashes Slackware with 1.2.13
Ulrich Thoenes
ulrich.thoenes at rhein-neckar.de
Mon Dec 11 07:00:00 EST 1995
Hello from Heidelberg.
In some sense my problem might touch both groups.
So please don't be bad with me if I am wrong in info.grass.user
Grass, a very good GIS system running also on linux requires handling
with sometimes big datasets. (A gziped file with 24MBytes results in
some 68MBytes unziped). When I tried to handle this files regardless
they were gziped or not I run into problems meaning that my whole
Linux System broke down. The only way out of it was to do a hardware
reset. (I know, shouldn't be done with linux).
WHat I mean with handeling is:
Copying or moving from one directory to another regardless these
directories are on the same partition / disk or not.
Un-taring a big tar file (tar -xf xxx.tar)
gezping a large .gz file (gzip -d xxx.tar.gz)
Especially in the last case the process stoped an some point resulting
in a partial ungziped file as I found out after reboot and
reorganizing the filesystem with a fsck during bootup.
Even when mounting the big 500MByte partition I some times get a
system crash.
I tried to work on both a primary partition or a logical partition on
a extended partition. The filesystem I used in both cases was ext2.
The size of the partition was in both cases about 500MByte of a 1090
Mbyte disk. (IBM DPES 31080)
The interesting thing is that I did not had similar problems when
worked on a 400MByte Partition of the same disk under DOS-Windows.
I actually did not try to handel that big files. The biggest I
handeled was som 3.5MByte. This worked without problems.
To make the storry complete I should say, that I succeded sometimes to
handel the big files just directly after switch on of my computer and
boot of Linux. I very recently had a problem with one of my power
supply kabels not giving the right contact, resulting in some 9.8
Volts instead of 12.00 Volts. I was able to fix this problem now and
do have stable 12.0 Volts all the time.
In addition when I do some formating or some fdisk stuff I get the
following warning:
The number of cylinders for this disk is set to 1034.
This is larger than 1024, and may cause problems with some software.
Here you'll find my total organization of my four disks.
IDE drive:
/dev/hda1 1 1 723 151812+ 6 DOS 16-bit >=32M
/dev/hda2 732 732 965 49140 83 Linux native
/dev/hda3 * 724 724 731 1680 a OS/2 Boot Manager
/dev/hda4 966 966 989 5040 82 Linux swap
1st SCSI drive:
/dev/sda1 1 1 150 153584 6 DOS 16-bit >=32M
/dev/sda2 151 151 206 57344 83 Linux native
2nd SCSI drive:
/dev/sdb1 1 1 107 109552 6 DOS 16-bit >=32M
/dev/sdb2 108 108 346 244736 5 Extended
/dev/sdb3 347 347 507 164864 83 Linux native
/dev/sdb5 * 108 108 246 142320 7 OS/2 HPFS
/dev/sdb6 * 247 247 346 102384 6 DOS 16-bit >=32M
3rd SCSI drive:
/dev/sdc1 1 1 412 421872 6 DOS 16-bit >=32M
/dev/sdc2 413 413 512 102400 82 Linux swap
/dev/sdc3 514 514 1023 522240 5 Extended
/dev/sdc5 514 514 1023 522224 83 Linux native
/dev/hda1 is the DOS System drive
/dev/sdb3 is the Linux System drive
/dev/sdb5 is the OS/2 System drive
/dev/sdc2 linux swap is as big as 100MByte because of the GIS
application.
I am running Slackware 2.3 with Kernel 1.2.13
My computer is a i486DX2 66MHz.
Further components are Adaptec SCSI cont. AHA1542CF,
VL bus controler,
3rd and 4th serial high speed port
4speed cdrom plextor, SCSI
1 Speed cdrom Mitsumi (the very old one)
Soundblaster pro,
Tsengslab ET4000W32 graphic card
Connor QIC Floppy streamer
This got a long posting. However it should be complete.
I would be very thankfull for any help.
Thanks Ulli
email: ulrich.thoenes at rhein-neckar.de
