program for filling in extra points on vectors - complement of v.prune
Simon Cox
s.cox at dem.csiro.au
Thu Feb 9 23:38:41 EST 1995
After my questions yesterday I realised that I could do it myself using the
dig_ascii format. I am putting a script
v.plant
into incoming on the moon. This is an interactive script which takes an
existing vector (dig) map and fills in extra points on long arcs according
to a specified threshold. I have only tested it on files with lines (not
area edges) so I will be grateful for feedback on other types. If someone
has a better suggestion for a name, then that will be good too - it is a
sort-of pun on v.prune which does the opposite (I first thought of calling
it v.plum!)
If you like it, make it executable and put it in your grass/scripts directory.
Programmers note: I wrote it as a Bourne shell-script, with the main work
done by awk (nawk, actually), which saved having to fiddle with Dave Gerdes
c-code in v.prune which I had a quick look at, before fleeing. I have
tried to document it clearly.
Enjoy!
___________________________________________________________
Dr Simon Cox __ \
CSIRO Exploration & Mining ,~' L_|\ Australian
39 Fairway, PO Box 437, ;-' \ Geodynamics
Nedlands, WA 6009 Australia ( \ Cooperative
Phone +61 9 389 8421 + ___ / Research
Fax +61 9 389 1906 L~~' "\__/ Centre
s.cox at dem.csiro.au 7
