r.profile     HELP!!!!!
    KLENKUS1 at VAXC.STEVENS-TECH.EDU
    Tue Jan 24 15:22:00 EST 1995
O.K.  r.profile is supossed output the values along a
defined line.
Problem.  what seems to be happening is that for distance this
will happen and then it desides to start from a new point
on the line and work back to the old one.
for example:
say x is constant.
start y = 20
      y = 30
      y = 40 goes to 30
      y = 50 goes to 40
Get it?  Has anyone run across this problem before.
Also d.profile gives the correct profile line.
Help.  Thanks for any assistance you can give?
Kym M. Lenkus
DAVIDSON LABORATORY
