GTCO digitizer setup
Morris Trimmer mtrimmer at liberty.uc.wlu.edu
Thu Jan 26 13:16:49 EST 1995
  We are trying to set up a GTCO Super L II Plus digitizer to run with GRASS4.1.
It is not working! Via UNIX commands I am able to communicate with the digitizer
board and it seems to be working fine. But when ever I try to run v.digit I get
to this page with the error message:
|                        POINTS TO REGISTER                                   |
|     POINT             EASTING (X)           NORTHING (Y)                    |
| ->     1.             654000.00           	4166000.00
|	 2.		654000.00		4179000.00
|        3.		644000.00		4179000.00
|        4.		644000.00		4166000.00
| Number of points: 4,   Points registered: 0                                 |
|USE KEYBOARD FOR INPUT                                                       |
| Digitizer read error.Do we continue(y,n)?                                   |
|  Key <2> - skip point,          Key<5> - accept residuals                   |
|  Key <3> - unregister point                                                 |
 Answering 'y' appears to do nothing and 'n' takes me out of v.digit. After
leaving v.digit the digitizer is hung and needs resetting. Our digitizer has a 4
button 'Cursor'('mouse'). I changed the digitizer file to reflect that but is
that enough?
 Any suggestion would be greatly appreciated.
Morris Trimmer
University Computing
Washington & Lee University
mtrimmer at wlu.edu
703-463-8846
