GRASS and simulation models
James Darrell McCauley
mccauley at ecn.purdue.edu
Wed Jan 25 12:54:04 EST 1995
James Darrell McCauley (mccauley at ecn.purdue.edu) writes on 19 Jan 95:
>Tim Martin (martin at ulysses.sis.ualberta.ca) writes to
>grassu-list at moon.cecer.army.mil on 19 Jan 95:
>>[Bernd wrote, re - Integrating GRASS and simulation models]
>>> I know of ANSWERS, AGNPS and TOPMODEL as being integrated, WEPP is about
>>> to be implemented, but there still only a hillslope version is existing.
>>WEPP - ??
>see the WEPP page at:
> http://soils.ecn.purdue.edu/~wepp/
> http://soils.ecn.purdue.edu/~del/
>I see that he's made the source code and documentation available via
David tells me that this is only a DOS executable and associated
(hillslope) interfaces. He says that the user interfaces do run under
UNIX but have not been compiled in a while.
David says that WEPP *itself* does support the watershed version, but
"without some sort of interface, it can be a humiliating experience to
attempt to run WEPP from the command-line." He is currently finishing
up an interface. For more info, ask del at ecn.purdue.edu.
--Darrell
