Projection Lambert III,
Simon Cox
S.Cox at solo.ned.dem.csiro.au
Tue Jun 27 08:00:00 EDT 1995
At 4:10 PM 26/6/95 +0100, Eric Den BREEJEN wrote:
>Hello,
>I need my database in Lambert Conformal Conic projection.
>My problem is when I use the hints given by Philip Verhagen, I get an error
>PROJECTION: 5 (** unknown **)
>I tried all projection values but my grass version GRASS 4.1 (Spring 1993)
>Update package 3 only knows
> PROJECTION: 3 (Latitude-Longitude)
> PROJECTION: 2 (State Plane)
> PROJECTION: 1 (UTM)
I think you need projection 99 (others) and then specify LCC when it asks you.
Simon Cox
___________________________________________________________
Dr Simon Cox __ \
CSIRO Exploration & Mining ,~' L_|\ Australian
39 Fairway, PO Box 437, ;-' \ Geodynamics
Nedlands, WA 6009 Australia ( \ Cooperative
Phone +61 9 389 8421 + ___ / Research
Fax +61 9 389 1906 L~~' "\__/ Centre
simon at ned.dem.csiro.au W
AGCRC info>> http://www.dem.csiro.au/simon/crc/intro.html
