Solaris 2.4 compiling
joe leone joe.leone at per.dwe.csiro.au
Tue Jun 20 08:00:00 EDT 1995
Hi all,
There has been some discussion on compiling GRASS on Solaris during the last
few months. I have tried to compile GRASS on Solaris 2.4 and have come across
some errors. Some of these have been mentioned before, but I did not find a
response or solution. The first was regarding Mike Camann's posting. I have the
a similar error ( include message 2).
Is the solution sugested by Mike the way to go?
I continued the compilation with the -skip option and came across the error
message
with libgis.a. I run into the same error if I did another -skip.
The header file has the same options as that posted by Martijn (14-jun-1995).
I also tried compiling with -fwritable-strings in the CFLAGS as sugested by
Darrel
in a Apr 95 posting.
I am using Gcc 2.7.0 and have not installed any extra X11 stuff.
Any Ideas what is gong wrong???
Thank you
Joe
Joe.leone at per.dwe.csiro.au
********Begin include message 1*******
../fonts/romanc.hmp
../fonts/romancs.hmp
../fonts/romand.hmp
../fonts/romans.hmp
../fonts/romant.hmp
../fonts/scriptc.hmp
../fonts/scripts.hmp
rm -f splitfont font_2_bin font.bin
GISGEN: src/front.end - Tue Jun 20 14:31:33 WST 1995
/home/joe/src/grass4.1.5/src/front.end
  mkdir OBJ
  make -f OBJ/make.rules
rm -f OBJ/main.o
gcc -O  -I/home/joe/src/grass4.1.5/src/include  -c main.c
main.c:159: warning: `warn' was declared implicitly `extern' and later `static'
mv main.o OBJ/main.o
gcc -s -o /usr/local/grass4.1.5/etc/front.end OBJ/main.o /home/joe/src/grass4.1
5/src/libes/LIB/libgis.a
gcc: /home/joe/src/grass4.1.5/src/libes/LIB/libgis.a: No such file or directory
make: *** [/usr/local/grass4.1.5/etc/front.end] Error 1
GISGEN failure at STEP: src/front.end
*********end include message 1*********
********Begin include message 2*******
gcc -O -DGETHOSTNAME_UNAME -I/home/joe/src/grass4.1.5/src/include  -c ialloc.c
mv ialloc.o OBJ/ialloc.o
rm -f OBJ/index.o
gcc -O -DGETHOSTNAME_UNAME -I/home/joe/src/grass4.1.5/src/include  -c index.c
mv index.o OBJ/index.o
rm -f OBJ/intr_char.o
gcc -O -DGETHOSTNAME_UNAME -I/home/joe/src/grass4.1.5/src/include  -c intr_char
c
intr_char.c: In function `G_intr_char':
intr_char.c:17: storage size of `buf' isn't known
intr_char.c:19: `TIOCGETC' undeclared (first use this function)
intr_char.c:19: (Each undeclared identifier is reported only once
intr_char.c:19: for each function it appears in.)
make: *** [OBJ/intr_char.o] Error 1
GISGEN failure at STEP: src/libes/gis
********END include message 2*******
********Begin include message 3*******
Date: Thu, 30 Mar 1995 17:38:40 -0500
Reply to: grassu-list at max.cecer.army.mil
Sender: grass-lists-owner at moon.cecer.army.mil.
Reply-To: grassu-list at moon.cecer.army.mil.
Precedence: Bulk
To: grassu-list at max.cecer.army.mil
Cc: grassp-list at max.cecer.army.mil
Subject: Compilation problem (Solaris)
Sorry if you get this twice, but I posted it to grassp-list as well as
grassu.
When compiling GRASS 4.1 (update 5) on a Sun SPARC 20 under Solaris 2.4
(? it's SunOS 5.4) I get the following compiler error shortly after
starting GISGEN:
cc -O -Xs -DGETHOSTNAME_UNAME -I/gis-soft/grass4/src/include  -c
"intr_char.c", line 17: incomplete struct/union/enum tchars: buf
"intr_char.c", line 19: undefined symbol: TIOCGETC
"intr_char.c", line 20: undefined struct/union member: t_intrc
cc: acomp failed for intr_char.c
make: *** [OBJ/intr_char.o] Error 2
Take a look at $GIS/src/libes/src/intr_char.c.  The incomplete struct
and the undefined symbols refer to definitions that should be found in
<sgtty.h> when  #ifdef USE_TERMIO is undefined, as is the case on my
system. The <sgtty.h> file in SunOS 5.4 is VASTLY different, however,
from the one in SunOS 4.1.1, where I have successfully compiled GRASS
many times (and where this particular preprocessor directive works
fine).  That's /usr/include/sgtty.h.  Under SunOS 4.1.1, tchars and
TIOCGETC are actually defined in <sys/ttold.h>, which is #included in
<sgtty.h>; t_intrc is an element of (struct) tchars.  These definitions
are entirely missing in the SunOS 5.4 version of <sgtty.h> which does
not #include <sys/ttold.h>.
Am I correct in assuming that this is the root of the problem?  Should
I add #include <sys/ttold.h> to the preprocessor directives in
intr_char.c?  If so, why wasn't this done in the source code prior to
release?  The fact that it wasn't makes me suspect that this is not a
good solution.
Can anyone who has successfully compiled GRASS under Solaris 5.4 tell
me how to fix this?  Are there any other surprises in store?
Michael Camann                  camann at dial.pick.uga.edu
Department of Entomology        camann at sparc.ecology.uga.edu
University of Georgia           (706) 542-2303 voice
Athens, GA 30602                (706) 542-2640 FAX
********End include message 3******
