digitizer stty?
Robert C. White Jr. rcw at csn.org
Mon Mar 27 01:37:21 EST 1995
In article <199503242045.OAA01098 at max.cecer.army.mil> you wrote:
: GRASSers,
:  I am trying to get a digitizer set up to run on our system with
: GRASS. I have been running into problems and my system adm. asks
: that I find out
:  'What stty or gettydefs peramiters need to be set up for the port
: the digitizer is connected to?'
:   My port is /dev/ttyr8 and the current settings as seen by the
: command # stty -a </dev/ttyr8 are:
You can forget gettydefs - it only is read by getty when  trying to login a
user.  You should make sure that there is no process trying to
run a login - or you won't be able to connect your digitizer.
About the other stuff - it's digitizer dependent.  Good luck, make chure you
chmod the port to permission 666!
Robert C. White, Jr.                                        rcw at whitestar.com
The WhiteStar Corp                                                 Malamutes!
Digital Cartography                     Mush and mush and mush and mush and...
Englewood, Colorado                     Just double click on the snow nose...
