infos on GRASS/LINUX/PC
Robert C. White Jr.
rcw at csn.net
Mon Mar 27 01:30:31 EST 1995
Thomas Hack (hack at typhoon.sdsu.edu) wrote:
: - What are your recommendations regarding hardware (e.g.
: incompatiblities to avoid ...)?
This is a huge land mine area. There are several CD-ROM drives out there
that Linux *does not* yet support. I had the Yggdrasil CD-ROM sitting around
here for months before I finally just disposed of my old CD-ROM and purchased
a new IDE based one (a Sony 55U, I believe) .
You should read the FAQs and newsgroups related to comp.os.linux.*
There is a steep learning curve.
Once I've gotten Linux installed, I have to say I am flabbergasted at the power
one can get on an intel based computer. I am running Linux version 1.2 and
am amazed that 1) it's free and 2) it's so stable. I'm a veteran of old
PC unixes like Microport and Linux is much, much better than than.
: - Where can I obtain LINUX? Any hints for smooth installation?
You can purchase several commercial distributions, or you can ftp it from
sunsite.unc.edu.
: - Can I have a UNIX and a DOS partition on the same PC?
Yes - as well as an OS2 partition, an NT partition, etc. etc.
: - Is there a compiled version of GRASS for LINUX available?
I've recently downloaded the version from moon.cecer.army.mil. I'm
not sure how good it is yet, though - I have been having some trouble with
the X window setup.
: I assume LINUX will come with a C-compiler (gcc?)?
Yes - gcc.
: Any suggestions for compiling GRASS modules for LINUX?
Haven't tried it yet.
: Are there any documents on the Internet that may describe
: some of the above? Where can I find them?
Look on the aforementioned ftp sites.
Robert C. White, Jr. rcw at whitestar.com
The WhiteStar Corp Malamutes!
Digital Cartography Mush and mush and mush and mush and...
