v.digit -Reply -Reply
    Abeer Alnaji
    alnaji at brcsun0.tamu.edu
    Wed Mar 22 15:22:48 EST 1995
> The problem I have v.digit is when the digitizer is set to none.  I assumed
> that meant I could work on vector files (assign cats, etc.) on the screen.
> Was that a bad assumption?
> PS xdigit works very well.
> PPS I am mainly interested in converting a vector file into raster.  The
> vector file is in Arc ungen format but does not have any labels.  As it
> currently exists, v.to.rast converts nothing because there is no label file
> in dig_att directory.  I can go through the ascii vector file from Arc, grab
> the values for a point on each of the lines and put it into the dig_att
> directory, but I was hoping that somebody had a routine that did this
> already.  I can't go back to Arc and have the file generated there.  Any
> tips greatly appreciated!
>----- End Included Message -----
Hello Gerald,
        No, your assumption about choosing 'none means no digitizer' is not bad
, it is exactly right and thats the only thing you can choose in this case and
it is for vector maps and yes you can
 assign values to areas/lines.
        And for the other problem with converting from arc to grass; in arc, yo
u need to UNGENERATE  a "line" file and a "point" file, just give each one a di
fferent .ext, maybe map.lin and map.pnt, then in grass you import using "v.in.a
rc" using "map.lin" for "lines_in" and "map.pnt" for "points_in" and the same "
map.pnt" for "text_in" and for the last three options use "1" for label, which
means using the first colmn in your *.pnt file as an att for your dig_att file.
  Then you need to run
 "v.support" and finaly "v.to.rast".  Now if you want more detailed labels in y
our cats file, then
 you need to use "OUTPUT" in arcINFO after you select the needed colmn for your
 cat file.  See OUTPUT in your INFO manual.
Well, I hope this helps you solve your problem.  Good luck!!
Abeer AL-Naji
