mayday (m'aidez) our monitors are sick
David Houlder
david at dart.anu.edu.au
Thu Mar 9 02:12:31 EST 1995
Tom...
> We have an epidemic of monitors failing.
> I've only lost the use of x0 but other people have lost
> x1 and x2 (we'll run out soon!.
> We have been using GRASS for ages and this has only just
> started, anybody got any bright ideas?
I don't suppose you're using the Solaris message-queue version of
the xdriver? If so, the problem is that the message queues don't always get
deleted, especially, I think, when you clobber the plot window from the
window manager rather than using d.mon stop= .
To fix, use the unix ipcs and ipcrm commands. See man pages. You
probably have to be root. Or reboot, but thats a less than elegant
approach. BTW, as others have reported, the ye olde fifo version workd
quite well under Sol 2.3 and 2.4.
If you're not using the message queue version, I dunno. Check the
permissions on the fifos maybe.
David Houlder Phone: +61 6 249 4613
Geography Department (In Aust.: (06) 249 4613)
The Australian National University Fax: +61 6 249 3770
