Offset problems with i.in.erdas
Maurice Hall
hall at gpsr.colostate.edu
Thu Mar 23 06:49:50 EST 1995
We are attempting to import files from Erdas using i.in.erdas.
We run i.in.erdas specifying an Erdas .gis file as the input file.
We then edit the GRASS header file to specify the correct projection
and UTM zone. The resulting raster map looks good, but is offset
several pixels (in this case approximately 100-200 meters) north and
west of where it should be.
Any insight into this problem would be appreciated.
Maurice
Maurice D. Hall, Graduate Research Associate
Water Quality Modeling
USDA-ARS-NPA TEL: 303-490-8336
Great Plains Systems Research FAX: 303-490-8310
P.O. Box E INTERNET: hall at gpsr.colostate.edu
301 S. Howes Rm. 215
Fort Collins, CO 80522
