Theissen polygons
julied at robinhood.ssmc.noaa.gov
Thu Oct 19 08:00:00 EDT 1995
I kept track of the Theissen polygon discussion (Sept 95) because I have a
need to make Theiseen polygons for a project I'm working on.
I tried to use s.surf.idw with the # of interpolation points set to 1, but
s.surf.idw takes into consideration distance and value of cells.
The theissen polygons I need can't take the value of the sites, I only
want the distance to be weighted. I haven't gotten s.geom to work, will
it solve my problem?
Here is the discussion:
From: stewalt at ncrds.er.usgs.gov (Sue Tewalt x6437)
Subject: creation of polygons from points
Date: Wed, 27 Sep 1995 12:05:53 -0400 (EDT)
Someone posed a question to me about delineating polygons around
points (sites), sort of splitting the distance between points to create
a "polygon of influence" of each site. The sites are unequally distributed.
Would this best be done by converting the sites to a raster and using
r.neighbors or an r.mapcalc statement to "grow" the site cells?
Advice would be appreciated--- thanks in advance
Date: Wed, 27 Sep 1995 13:27:53 -0400
Subject: Re: creation of polygons from points
This sounds like a standard Voronoi tessellation problem to me. There is a
tar distribution called s.geom in /incoming on the moon site that contains
modules to generate these polygons with GRASS.
Cliff Behrens
Date: Wed, 27 Sep 1995 15:39:18 -0400 (EDT)
It sounds like you want to do Thiessen polygons.
I know they can be done with Arc/Info, but I'm new to GRASS.
Date: Tue, 3 Oct 1995 09:57:29 +0100
I haven't been following this thread closely so someone may have
mentioned this but you can make veronio/theisson/proximal polygons
by using s.surf.idw and setting the number of interpolation points
to 1. You get a raster rather than a vector map but it's quick.
cheers Tom 8-)
Date: Wed, 27 Sep 95 12:22 CDT
I believe that the term that you are looking for is "voronoi diagram."
This may be found using the GEOM package:
ftp://moon.cecer.army.mil/grass/incoming/geom.tar.Z
Darrell
P.S. avoid temptation and do not use s.voronoi in src.contrib.
It has a bug which I do not care to fix (GEOM is much
more extensive).
James Darrell McCauley, PhD http://www.mcs.com/~mccauley/
16W518 Honeysuckle Rose Lane #214 mccauley at mcs.com
Hinsdale, Illinois 60521 USA tel: 708.655.0643
Date: Wed, 27 Sep 95 11:30:13 PDT
From: alhinc at cicese.mx (Alejandro Hinojosa Corona)
You could try v.cicle, here is a piece of the man page:
v.circle - Creates one or more "polygon" circles in a binary
vector file. These circles are created using each point
from an existing "site_lists" file as the centers for those
circles. There is one circle created per "site_lists"
point.
(GRASS Vector Program)
Alejandro Hinojosa
I hope this helps.
Julie Daniel
julied at littlejohn.ssmc.noaa.gov
