compile problem d.display
Tim Miller
tmiller at bvu-lads.loral.com
Wed Oct 25 15:39:19 EDT 1995
Hello all GRASS users,
Has anyone had problems compiling the fp-code, and not been able to compile d.display?
Any help will be appreciated.
Thanks
Tim Miller
Heres the output from the compile:
GISGEN: src/display/d.display - Wed Oct 25 12:48:29 PDT 1995
/usr/chisos/sd0h/tools/arcinfo/grass41/src/display/d.display
make -f OBJ.sun4/make.rules
rm -f OBJ.sun4/cell3d.o
gcc -O -I/usr/chisos/sd0h/tools/arcinfo/grass41/src/include -c cell3d.c
mv cell3d.o OBJ.sun4/cell3d.o
rm -f OBJ.sun4/cell_map.o
gcc -O -I/usr/chisos/sd0h/tools/arcinfo/grass41/src/include -c cell_map.c
mv cell_map.o OBJ.sun4/cell_map.o
rm -f OBJ.sun4/color.o
gcc -O -I/usr/chisos/sd0h/tools/arcinfo/grass41/src/include -c color.c
mv color.o OBJ.sun4/color.o
rm -f OBJ.sun4/digitize.o
gcc -O -I/usr/chisos/sd0h/tools/arcinfo/grass41/src/include -c site.c
mv site.o OBJ.sun4/site.o
rm -f OBJ.sun4/use_mouse.o
gcc -O -I/usr/chisos/sd0h/tools/arcinfo/grass41/src/include -c use_mouse.c
mv use_mouse.o OBJ.sun4/use_mouse.o
rm -f OBJ.sun4/vect_map.o
gcc -O -I/usr/chisos/sd0h/tools/arcinfo/grass41/src/include -c vect_map.c
mv vect_map.o OBJ.sun4/vect_map.o
rm -f OBJ.sun4/zoom.o
gcc -O -I/usr/chisos/sd0h/tools/arcinfo/grass41/src/include -c zoom.c
mv zoom.o OBJ.sun4/zoom.o
gcc -s -o /usr/chisos/sd0h/tools/arcinfo/grass41//etc/bin/main/inter/d.display OBJ.sun4/cell3d.o OBJ.sun4/cell_map.o OBJ.sun4/color.o OBJ.sun4/digitize.o OBJ.sun4/do_exit.o OBJ.sun4/do_pause.o OBJ.sun4/gorun.o OBJ.sun4/histo.o OBJ.sun4/label.o OBJ.sun4/legend.o OBJ.sun4/menu_disp.o OBJ.sun4/menu_info.o OBJ.sun4/menu_main.o OBJ.sun4/msurement.o OBJ.sun4/scale.o OBJ.sun4/setup.o OBJ.sun4/show_cell.o OBJ.sun4/show_leg.o OBJ.sun4/show_region.o OBJ.sun4/site.o OBJ.sun4/use_mouse.o OBJ.sun4/vect_map.o OBJ.sun4/zoom.o /usr/chisos/sd0h/tools/arcinfo/grass41/src/libes/LIB.sun4/libD.a /usr/chisos/sd0h/tools/arcinfo/grass41/src/libes/LIB.sun4/libdisplay.a /usr/chisos/sd0h/tools/arcinfo/grass41/src/libes/LIB.sun4/libraster.a /usr/chisos/sd0h/tools/arcinfo/grass41/src/libes/LIB.sun4/libgis.a /usr/chisos/sd0h/tools/arcinfo/grass41/src/libes/LIB.sun4/libvask.a -lcurses -ltermlib -lm
ld: Undefined symbol
_G_make_random_fp_colors
_G_make_grey_fp_scale_colors
collect: ld returned 2 exit status
*** Error code 1
make: Fatal error: Command failed for target `/usr/chisos/sd0h/tools/arcinfo/grass41//etc/bin/main/inter/d.display'
GISGEN failure at STEP: src/display/d.display
