settings for ImageAlchemy & NovaJet?
Mark Gibb gibb at hubers.cecer.army.mil
Mon Oct 30 16:15:02 EST 1995
Malcolm-
Use the following command line for Image Alchemy PS:
alchemy --r10 -Ze1 -Zf1 -Zm2 <in.psfile> <out.rtlfile>
Make sure the following variables are set:
ALCHEMYPS  (which points to alchemy_install_dir/ps directory)
Mark Gibb
USACERL
----- Begin Included Message -----
>From grass-lists-owner at max.cecer.army.mil Mon Oct 30 13:13:09 1995
Date: Mon, 30 Oct 1995 12:55:06 -0600 (CST)
From: Malcolm Williamson <malcolm at cast.uark.edu>
X-Sender: malcolm at cast
Sender: grass-lists-owner at max.cecer.army.mil
Reply-To: grassu-list at max.cecer.army.mil
Sender: grass-lists-owner at moon.cecer.army.mil.
Reply-To: grassu-list at moon.cecer.army.mil.
Precedence: Bulk
Subject: settings for ImageAlchemy & NovaJet?
MIME-Version: 1.0
Content-Type: TEXT/PLAIN; charset=US-ASCII
Content-Length: 569
Hi
Does anyone out there use Image Alchemy to convert ps.map-generated files
to print on an Encad NovaJet II inkjet plotter? If so, would you be so
kind as to pass on the parameters that you are using with Image Alchemy
to get satisfactory images? Thanks for any and all help!
Malcolm D. Williamson - GIS Specialist           E-mail: malcolm at cast.uark.edu
Center for Advanced Spatial Technologies      Telephone: (501) 575-6159
Ozark Rm. 12                                        Fax: (501) 575-5218
University of Arkansas
Fayetteville, AR 72701
----- End Included Message -----
