Error starting graphic monitor
Baxter E. Vieux
vieux at nouvelot.orstom.fr
Thu Sep 7 08:00:00 EDT 1995
> We suppose that this could be a lock file problem.
Check the directory $GISBASE/locks/name_of_your_workstation
If a file similar to the following exists:
-rw-rw-rw- 1 baxter sys 12 Aug 28 14:08 mon.20852
Try removing it. Also make sure that under $GISBASE/dev that the
pipe for x_whatever does not have any bytes in it. If it does
simply remove it and recreate it with mknod <name> p
