Can I connect the dots ???
charnotw
charnotw at helios.aston.ac.uk
Wed Sep 13 13:23:48 EDT 1995
> I am using grass4.1
> I have several points derived from a gps unit that I would
> like to convert into vector files, with the sites interconnected
> by arcs or lines.
> Is there a command that will do this or do I have to do this
> manually using digit ?
> Thanks for the help, in advance
> Bonnie
The easiest way I can think off would be to manually construct a
ascii vector file, put this into dig_ascii directory in your mapset
and run v.in.ascii. You can find the format for a ascii vector
file in the programming manual basically it looks like this:
8<-----------------------------------------------------------
ORGANIZATION: Aston Uni UK
DIGIT DATE:
DIGIT NAME:
MAP NAME:
MAP DATE:
MAP SCALE: 50000
OTHER INFO:
ZONE: 0
WEST EDGE: 355000
EAST EDGE: 370000
SOUTH EDGE: 320000
NORTH EDGE: 333000
MAP THRESH: 38.1
VERTI:
L 6
332941.1359081 361975.26726477
332875.44181619 362008.11431072
332809.74772429 362172.34954048
332793.32420131 362451.54943107
332776.90067834 362566.5140919
332744.05363239 362681.47875274
L 3
332941.1359081 365112.16015317
332826.17124726 365030.04253829
332744.05363239 364997.19549234 etc etc
The L means a line (or A for area) and the number is the number of
coordinate pairs following. You may be able to write a script that
will convert your data to this automatically.
cheers Tom
Tom Charnock O--O
Dept Civil Engineering (~~~~)
Aston University ( __ )
Birmingham B4 7ET UK /|\ /|\
charnotw at sun.aston.ac.uk
