ps.map to powerpoint
Le Squal - UHB - 99 14 13 47
gouery at uhb.fr
Mon Apr 22 08:00:00 EDT 1996
>Group: info.grass.user, Item 8270 (Range: #8239 - #8272, Unread: 2)
>Subject: ps.map to powerpoint
>From: chiang at unconfigured.xvnews.domain (Chang-Chou Chiang), The
>Date: 10 Apr 96 20:15:47 +0100
>Does anyone know how to convert the maps generated by ps.map to
>the format readable to powerpoint or other graphic softwares?
>Thanks for your help.
Powerpoint imports many formats, but i never try to import a file created
by ps.map as "EPS" file ... may be it's ok ...
If not i think many solutions :
- Use a converter between the ps file and another format (for example :
BMP, TIFF ...) : for my own, i do this using the converter of the free
package ImageMagick associated with GhostScript.
- Another way is to capture the content of your display with another tool
than ps.map : for that, ImageMagick is also a very good tool - using a
command like "convert X: filename.format" allows you to capture the
content of a window or a part of a display in many raster formats. I think
for best results, you have to adjust the size of your display (in your
".grassrc" file with the lines XDRIVER_HEIGHT and XDRIVER_WIDTH)
Hope this helps you,
[EOB]
| Pascal GOUERY : Tel.: 99.14.13.47 |
| C.R.I. : 99.14.13.52 |
| Universite de Rennes 2 : Fax.: 99.14.13.50 |
| 6, Av G.Berger : |
| 35043 RENNES CEDEX : e.mail: Pascal.Gouery at Uhb.Fr |
| FRANCE : |
