need help (MSS, raw file import)
    Le Squal - UHB - 99 14 13 47
    gouery at uhb.fr
    Mon Apr 22 08:00:00 EDT 1996
>Group: info.grass.user, Item 8239   (Range: #8239 - #8272, Unread: 5)
>Subject: need help
>From: pubu at gfi.uib.no (Pu Bu Ci Ren), University of Illinois at Urbana
>Date: 2 Apr 96 09:05:24 +0100
> reading data in other place, transfer it  to my hard disk, then I use small
>program which is written by me to extract each band file from the big image
>file on hard disk, the data format is 8 bit binary file, I use XV to
>display it, it is successful.
>When I use grass, I created a location and mapsheet for mss data, I input the
>column and row number( 3600, 2286), then move all four band files to directory
>cell under mapsheet MSS, then I try to use d.rast to display it, I got message
>: can't open rast file ...
Did you create the header file (in cellhd) ?
If not, try just using r.support.
                        Hope this helps.
        |       Pascal GOUERY           :       Tel.: 99.14.13.47            |
        |       C.R.I.                  :             99.14.13.52            |
        |       Universite de Rennes 2  :       Fax.: 99.14.13.50            |
        |       6, Av G.Berger          :                                    |
        |       35043 RENNES CEDEX      :       e.mail: Pascal.Gouery at Uhb.Fr |
        |       FRANCE                  :                                    |
