need help
Rick Thompson rick at cast.uark.edu
Wed Apr 10 08:00:00 EDT 1996
  You can use the r.colors command to assign a different color table. For your
background color after running r.colors, vi your $LOCATION/colr/"filename"
and change the rgb values for category 0.
Change like the following:
% 2 286
0:255           #This is white, 0:0 would be black, i.e. 0:0:0:0
1:117:140:85
2:88:155:184
3:166:190:80
Hope this helps. Rick
On Wed, 10 Apr 1996, Pu Bu Ci Ren wrote:
> I new user, I got problem, I was using d.rast to disply satellite image,
> the colour I choosed is grey scale, but I only get 2 colours: white and grey,
> does anybody know how to display image in 256 color(maybe it's not nesseary,
> but it is necessary to display more than 32 colors). I am using grass4.1,
> installed on SGI.
>  another problem is when I am trying to use d.display, the background colour
is
> grey, but the colour of menu is yellow, I even can't recoginize what it is,
> it is possible to change these default color tables ?
Rick Thompson-   Research Specialist          E-mail: rick at cast.uark.edu
Center for Advanced Spatial Technologies      Telephone: (501) 575-6159
Ozark Hall Rm. 12                             Fax: (501) 575-5218
University of Arkansas
Fayetteville, AR 72701
DISCLAIMER: Any opinions or comments about any product, organization,
            or individual expressed in the above text are my own.
